Diesel pump separation
Brad in WI
11-09-2005 09:26:03
Does anybody know if the scavenging pump is timed to the actual injection pump or not. Also how is it driven. Keyed, splined or ?. The books that I have doesn't say to much about removing and replacing it and I just want to be sure. Thanks for the help again.
Brad
DWV
11-09-2005 15:24:12
 Re: Diesel pump separation in reply to Brad in WI, 11-09-2005 09:26:03
If you mean a gas start diesel Its driven by a square coupling and not timed.On farm tractor like 400 D ETC remove fuel lines, strainer and 2 5/16 bolts and it will slide out.
El Toro
11-09-2005 15:15:27
What tractor is this? Hal
Brad in WI
11-10-2005 02:09:52
 Re: Diesel pump separation in reply to El Toro, 11-09-2005 15:15:27
Sorry about that forgot that part 47 MD gas start. If it is not timed have to take it out and hope that is my fuel flow problem. Hoping for just bad, leaking seals and gaskets.
Brad
DEWAYNE UTRUP
11-11-2005 09:28:37
 Re: Diesel pump separation in reply to Brad in WI, 11-10-2005 02:09:52
If you do have a problem with the primary (scavange) pump there is a good source for these parts. I got mine from John at Diesel Specialties in Sioux City, Ia. They are cheap to repair yourself. Good Luck.
