farmall colors
bub
11-09-2005 11:51:19
WOULD SOMEONE BE WILLING TO SHARE THE BRAND AND PAINT CODE THAT THESE BEATIFUL FARMALL TRACTORS ARE PAINTED WITH?.MY PAINT GUY REFUSES TO MIX ANY THING WITHOUT KNOWING SOME KIND OF CODE. PLEASE LIST SEVERAL BRANDS AND TYPES THAT MAYBE I CAN GET IN MY AREA.IS REGULAR ENAMEL PAINT SATISFACTORY? I DO NOT HAVE MUCH KNOWLEDGE OF THE PAINT END OF TRACTOR RESTORATION .I LIKE THE DEEP RED COLORS OF THESE TRACTORS.SOMEONE SURELY REMEMBERS WHAT THE PAINT NUMBERS AND BRAND WAS,AND WHAT ELSE I NEED TO PURCHASE, LIKE HARDENER AND THINNER. THANKS FOR ANY INFO ON THIS SUBJECT.
CNKS
11-09-2005 12:44:08
 Re: farmall colors in reply to bub, 11-09-2005 11:51:19
In order, the red colors were IH 50, IH 1102B, IH 201, IH 2150. Most people use 2150, although it did not appear until 1961. IH 50 crosses to PPG 70019/DuPont 7410. IH 2150 crosses to PPG 71310/DuPont 96766. A slight orange tint can usually be seen in the PPG version. I do not know if 201 or 1102B can be mixed. IH 50 was used from 1936 until sometime in 1949, I do not know the time periods of 1102B and 201, only that 1102B was used before 201, and that 2150 replaced 201. The best paint is acrylic urethane made by PPG, DuPont, or Sherwin Williams. The hardener used with it can be deadly, it REQUIRES a supplied air system. You can use acrylic enamel or acrylic modified alkyd enamel (2150 sold by Case-IH) without hardener. Anything of lesser quality (straight alkyd enamel sold by farm stores) is not worth messing with.
CNKS
11-09-2005 18:09:43
 Re: farmall colors in reply to CNKS, 11-09-2005 12:44:08
IH paint decisions in the Wisconsin Historical archives indicate that the use of IH 201 paint began being used on all tractors in 1958 with the introduction of the 460/560 and other models introduced about the same time. 201 was replaced by 2150 in Nov 1961 with the introduction of the 404 and 504.
Jason(ma)
11-09-2005 14:29:38
just a quick additon The PPG IH50 orange tint issue appears to be with the "Omni" line of paint, Not the "Concept" line. Same paint code, same brand, both Urethans.
CNKS
11-09-2005 17:30:01
 Re: farmall colors in reply to Jason(ma), 11-09-2005 14:29:38
I assume you mean 2150 has the orange tint, that's where I have seen the problem with Omni. I have not used 50 yet. Also thinking about using Concept. As to the orange, the DuPont 2150 (96766), so I am told, has no orange toners in it. Thus different manufactures have different toners in their paint, and although it supposedly matches the IH color, they are all have slightly different colors. Wish I had a brand new preserved 40's 50's tractor, so that I could actually see what the correct color is.
George Wallace
11-09-2005 12:28:04
Check out the following link then paint it any color you want. I used a urethane that turned out very well. A little pricey, but better paint than the emplement enamel. You can see my two farmalls at wallaceg.com
