serial number on H
bedrock1234
11-14-2005 07:01:13
I lbought a Farmall H that the motor was seized up and after the serial number someone stamped in X1. What is this suppose to repesent?
Thanks in advance.
Theman
11-14-2005 09:20:18
 Re: serial number on H in reply to bedrock1234, 11-14-2005 07:01:13
To expand what the other posts have stated a bit further: The gasoline engine had a bit more compression than the distillate or kerosene models. This was accomplished by a head with smaller combustion chambers. The valves had longer stems so the same push rods and rocker arm assemblies could be used. The manifold (cold) and carburetor (smaller jet) were different because the gas engine didn't need to pre-heat the heavier fuels.
El Toro
11-14-2005 07:33:06
I think to burn gasoline only. Hal
Farmall_Ryan
11-14-2005 07:32:07
X1 = gasoline engine
