1952 farmall md
bluegoose
11-15-2005 03:28:12
hello i was just wandering if any one could tell me if these tractors had the battery box under the seat i just got this tractor back after a number of years it was my uncles and just want to put it back to original when i redo it in memory of him thank you
Geoff NY
11-15-2005 16:11:43
 Re: 1952 farmall md in reply to bluegoose, 11-15-2005 03:28:12
The second battery and box described as optional equipment actually went on the platform at the right side of the conventional seat.
n9lhm
11-15-2005 04:07:53
Yes, they had a second battery box under the seat. #62514D for serial numbers 501 to 149583 and #352787R91 for serial numbers 149584 and above. They are rare as hen"s teeth, even the ones that are still on salvage tractors are rotted out like every other battery box on a salvage tractor.
Here"s what I did on mine -- I bought two regular M battery boxes and put one under the gas tank in the usual location. I took a piece of 1/4" steel plate and cut out a plate to fit on top of the transmission cover and about 4" longer than the battery box (2" extra each side). Then I drilled holes to match the transmission cover bolts to mount the plate, and brazed short bolts on top of the plate to mount the under-gas-tank style battery box. Painted it all up and it looks great, I"ve had a lot of comments on how nice it looks, and nobody has ever noticed that it is not exactly "original". Brian
RustyFarmall
11-15-2005 05:59:28
 Re: 1952 farmall md in reply to n9lhm, 11-15-2005 04:07:53
Why would a diesel engine that starts on gasoline need two batteries?
DWV
11-15-2005 09:25:22
 Re: 1952 farmall md in reply to RustyFarmall, 11-15-2005 05:59:28
To pack 2, 6 shooters for 12 shots. Little humor added.
DWV
11-15-2005 17:51:58
 Re: 1952 farmall md in reply to DWV, 11-15-2005 09:25:22
Rusty, a six volt battery was used in each box
and wired in series to make 12 volts.Geof in NY
correct on location of original box near seat.
Randy in NE
11-15-2005 03:53:06
Not according to the parts manual. There is a battery box (special) that is under the seat. The manual does not give any serial numbers that would be associated with it so my guess is that it was an option from the factory.
