Order Farmall Cub Parts Online
cub brakes
allan tallis
11-16-2005 18:58:59
I want to replace the brakes in my 1949 cub,can i remove the lower axle assy in one piece if i remove the cap and bearing for the differential shaft. I asume the differential will just pull out and allow you to remove housing and exposing the brake drum.
George Willer
11-16-2005 19:25:52
 Re: cub brakes in reply to allan tallis, 11-16-2005 18:58:59
Allan,
Your question isn't clear, but you can remove the complete final drives as assemblies. Do yourself a favor and follow the directions in the manual to use a sling and hoist. When you have the finals pulled out the brake work will be self evident.
Hint: Plan to replace the seals at the differential case... the bad seals leaking is the most likely reason you need to fix the brakes. The seals are usually bad because some hero decides he can do the job without a hoist and damages the seals.
George Willer
Nat
11-17-2005 05:18:20
 Re: cub brakes in reply to George Willer, 11-16-2005 19:25:52
Chain host works, but two guys can do it if they're careful.
George Willer
11-17-2005 08:01:31
 Re: cub brakes in reply to Nat, 11-17-2005 05:18:20
Two guys handling the final puts the seal at even greater risk. How in the world can you reliably handle 75 pounds accurately enough to avoid probable damage to the seal... unless you simply don't care? NOT ON MY CUB!
Peabody
11-16-2005 20:48:54
George, you sound like an IT Manual: "When you have the finals pulled out the brake work will be self evident."
Few times have I torn something loose that the repair was "self-evident".
Rudi
11-18-2005 14:19:42
 Re: cub brakes in reply to Peabody, 11-16-2005 20:48:54
Peabody:
If George wrote the I&T Manual, it would be far more useful than it is at it's current best use which for me is primarily as a paper weight..... not even a good one at that.
George explains things in such a way that even mechanically challenged folk such as myself have been able to fix and maintain our Cubs.
If George says it is sef-evident, then it is self-evident and anybody who knows what end is the business end of a wrench could fix it..
That kind of comment really was uncalled for.
Nat
11-17-2005 05:22:09
The I&T manuals assume some mechanical aptitude, you know... :)
Really, it is self-evident. If you can't figure out how the brakes work on a Cub, put down the wrench and just walk away... There's a metal wheel on the axle with a brake band around it. The metal wheel is fastened to the axle with a set screw and a woodruff key. It's not rocket science.
One of the brake wheels on my Cub came loose, and the woodruff key fell out. From what I've heard, that's a pretty common problem.
