What goes beside the ignition switch
Bob Underwood
12-04-2005 12:02:57
I have a 49M. The ignition switch is missing I will purchase one, there are two holes side by side I would like to know what goes in the other hole. Thanks Bob
Bob Underwood
12-05-2005 15:33:51
 Re: What goes beside the ignition switch in reply to Bob Underwood, 12-04-2005 12:02:57
Thanks for the replys.The 2 loops of metal are below the light switch. Thanks Bob
GooseCreek Farms
12-05-2005 03:07:13
I believe it is the hole where the crank goes for the shutter on Multi-fuel tractors.
farmallhal
12-04-2005 14:01:42
Bob, I think you are referring to the holes in the hydraulic control arm for the belly pump operating rod. If so, the other hole is where the shutter control rod crank is located for tractors with shutters. The switch goes in the hole to the left. Hope this answers your question. Hal
jimmy joe
12-04-2005 18:29:19
 Re: What goes beside the ignition switch in reply to farmallhal, 12-04-2005 14:01:42
He could be refering to fuse holder hole. jimmy joe
farmallhal
12-04-2005 18:43:36
 Re: What goes beside the ignition switch in reply to jimmy joe, 12-04-2005 18:29:19
Thanks Jimmy for the post and I thought of that at first but the fuse holder is in the amp gage/light switch box on my tractors. My H and M both have the push-pull ignition switch located on the belly pump control rod support arm. My part catalogs shows the switch in that location also. Hal
strictlyih
12-04-2005 12:40:03
how about a picture of the junk deere it replaced
