Hydrolics proublem
Brandon
01-01-2000 13:31:48
this is a basic hydrolic proublem. when i try to rasise my hydroilic up there is a "dead spot" and my draw bar drops untill i push it up fother then it catches and raises up. i have replaced the ram, the lines, all the gasgets on the ram, and checked all the gaskets on the pump. i think i covered pretty much every thing and im running out of money for this. im not sure that the handle is the factory one.any help? thanks!
Daniel
01-01-2000 15:42:19
 Re: hydrolics proublem in reply to Brandon, 01-01-2000 13:31:48
What kind of tractor are you working on? I know some of the IH levers had a soft metal insert that grabs the control valve shaft. This was soft so the splines on lever would wear out (which is cheaper and eaiser to replace) instead of the splines on the shaft in the valve. Maybe you lever is worn and slipping? Good Luck.
