Farmall H carb adj.
Andrew Z
12-06-2005 14:27:29
How do I tell weather or not the laod screw is adjusted correct? The tractor runs good after I rebuilt the carb, but I dont know excatly how to adjust the laod screw. Thanks for the help Andrew
CNKS
12-06-2005 17:30:39
 Re: Farmall H carb adj. in reply to Andrew Z, 12-06-2005 14:27:29
At wide open throttle with the engine warmed up, turn in until it begins to miss, turn out until smooth, then add an addition 1/4-1/2 turn. Needs to be adjusted in conjunction with the idle mixture, done the same way, except that turning the idle screw in richens the mixture.
old
12-06-2005 14:58:07
I alway adjust them so it pulls like I want it too so you have to work it some to do it that way. I've also heard you can open it up till you start seeing black smoke and then just close it a little till the smoke goes away.
Andrew Z
12-06-2005 17:03:10
 Re: Farmall H carb adj. in reply to old, 12-06-2005 14:58:07
Thanks I'll Try that Andrew
