52 Farmall H headlight switch resistor...
BillyinStoughton
12-06-2005 14:48:31
I have a 52 Farmall H with the a 3 position light switch. What is the value of the resistor used on the back of the switch for the "dim" bulb position?
Thanks boys!
Allan in NE
12-06-2005 15:05:22
 Re: 52 Farmall H headlight switch resistor... in reply to BillyinStoughton, 12-06-2005 14:48:31
Hi Billy,
It provides a means of adding a voltage drop in series with the circuit.
Allan
Janicholson
12-06-2005 17:16:10
 Re: 52 Farmall H headlight switch resistor... in reply to Allan in NE, 12-06-2005 15:05:22
Three Ohms at 70 watts dissipation Ceramic wire wound power resistor.
Or
It dims the lights (which is in my opinion adding insult to injury)
Or
$5.00 US to someone who needs it.
Or
$10.00 if you need to buy one (I don't have one)
Or
Nothing if it is burnt out.
JimN
BillyinStoughton
12-07-2005 06:20:35
 Re: 52 Farmall H headlight switch resistor... in reply to Janicholson, 12-06-2005 17:16:10
Three ohms at 70 watts it is then. Thanks for the info. A small visit to Radio Shack tonight and building my new harness will be complete! Thanks for the help. Stay warm...cause it was only -2 this morning up here, and at my young age, even I was a little stiff. Not as stiff as the 5W30 in the F-150s straight six though!
