broken cam on farmall m with live hyd pump
blair d s
12-20-2005 19:18:54
is there heavier cam and gears out there to buy?
DWV
12-21-2005 07:46:14
 Re: broken cam on farmall m with live hyd pump in reply to blair d s, 12-20-2005 19:18:54
Don't know about new but if you're looking at used the Cam gear part # that ends with letters DB
is the latest and supposed to be better.Some C-281
engines and some replacement cams came with left hand thread and nut to better hold cam gear from working lose.Don't think cam is any stronger though.
john d
12-21-2005 05:32:54
I don't know for sure, but there is a good chance that a cam and gear from a Farmall 400 or 450 would fit. That camgear is heavier than the original M gear.
Nat
12-21-2005 05:29:37
Depends on what you have now. If you have an IH live pump, then you've already got the heavier timing gears and the newer front cover. There's nothing heavier. You'll just have to be more careful.
