H parts
Bill Geer
12-28-2005 19:23:59
I got me a H parts tractor. I need to know how to take off two parts. 1. the rock shaft for the shutters.[up by the oil cap.] 2. The hand crank shaft.[through the bolster.] Thanks Bill
Farmer Bob
12-28-2005 23:35:10
 Re: H parts in reply to Bill Geer, 12-28-2005 19:23:59
Bill, I recommend a parts manual which will show you the exact way these items come apart. One item on the handcrank shaft, it is easier to remove it after taking off the upper bolster from the tractor so you can work on it without laying on your back under the tractor. You will need the clearance as well as it comes out the back side of the bolster and there no room to do this with the bolster attached.
kfox
12-29-2005 03:50:57
 Re: H parts in reply to Farmer Bob, 12-28-2005 23:35:10
The crank shaft ratchet can be removed by sliding the front retainer (held on by a snap-ring on the front end, and the spring) to the rear against the spring. Then you can push the pin out. Then the ratchet can be removed. There isn't enough clearence to get the shaft out unless you do as Farmer Bob says. I don't know if removing the front engine pulley would give you room, or not. It's much easier to remove the ratchet with the radiator off. I think the shutter rockshaft has a clamp bolt on one end. ken
