Wide Front End Headaches (Long)
Allan in NE
12-29-2005 17:23:36
Hi Guys,
I've been dreadin' this chore and naturally, I saved the worse part for last (takin' the slop outta the front end, along with the prior owner's patch job) and something just doesn't seem right with this one 'cause it doesn't turn sharp enough and just doesn't "feel" right.
It feels like an old M or H factory wide frontend when ya turn. Feels like something is wacko in the geometry of the thing. Won't spin around on one wheel like it should and seems to take more brake to bring 'er around. Too big of a turning radius, 'er something even tho the steering arm is coming all the way to the stops.
Steering arm and tie rods all are okay and are twins to my 686. Has the nicest power steering of any tractor I've ever owned.
When did IH start the cast center tube on the small frames?
This one is a '74 and it has a steel tube. Is it correct? Or should it have the cast center with the cast wishbone?
I'm wondering if maybe the prior owner put the wrong front end under it? Did the 656s have a steel tube? I can't remember. :>(
Allan
third party image
Jim J
12-29-2005 20:41:29
 Re: Wide Front End Headaches (Long) in reply to Allan in NE, 12-29-2005 17:23:36
The wide front on your tractor came off of a 460 or a 560. The front don't have the blocks for the turning arms on the axle extensions or on the turning arms. The turning arms on the 560 fronts are longer than the later fronts. What are the casting numbers on the hubs?
JakeF
12-29-2005 20:27:13
I was told that the steering arms on a 560 were shorter than on a 656, and the 656's do turn better than a 560, so I've always belived it. Maybee you have the short armed 560 front. Jake
JakeF
12-29-2005 21:04:28
 Re: Wide Front End Headaches (Long) in reply to JakeF, 12-29-2005 20:27:13
Oops, got my longs and shorts mixed up. The shorter arm will turn the tire farther. Jake
MN Scott
12-29-2005 20:25:24
On my 706 someone modified the factory center steering arm by welding a peice of steel on it and drilling two holes about 2 inch's back from the original holes for the inner tie rods. So when you turn short the tie rods are pushed/pulled an extra two inches. It turns noticeablly tighter. Also a way to identify a 60 series wide front is the original innner tie rod is 3/4 inch tread not 1 inch and is locked in place by a clamp not a lock nut like the newer 1 inch style, that is if it hase'nt been replaced by the new style 1 inch end and sleeve.
riverbend
12-29-2005 19:48:38
I'm not sure what all your problems are, but I have the same sort of thing with my SC. Narrow front steers like nobody's business. Turn on a dime and leave 5 cents change. With a wide front, it is a pig. It is like the front end always wants to push or drag. The schwartz wide front on my H works better.
It seems like it won't turn sharp enough, it's too short for the geometry.
K.B.-826
12-29-2005 18:52:43
Allan, I want to say that they changed to the cast stay rods when the 666 came along. However, that would have no effect whatsoever on turning radius. The 706-1456 have the exact same front bolster as the 656 family and every dimension of the front frame should be the same. One thing I do notice in your picture- that front end has the old style spindles and spindle arms that clamp on with a bolt. Measure the length of those arms and compair to your 686. If those arms are shorter, it will not turn as sharp. Also check out the steering arm (the piece the inner tie rod ends attach to) and compair to your 686, although I don't know why that part would have ever been changed in length.
Allan in NE
12-29-2005 19:28:52
 Re: Wide Front End Headaches (Long) in reply to K.B.-826, 12-29-2005 18:52:43
Good Catch!
I'll measure those arms tomorrow.
However, the radius arms on the large frames have got to be different than on the small framed tractors.
This is a picture of my 686. The front bolt on the Hydro 70's trunion mount lines up 2" rearward placing it directly under the motor mount. Cannot put a bolt to it because the engine is in the way.
I don't have to tell you how Barney Be-Devil and his trusty welder handled that little problem. I'm cutting the welds out now. :>)
Thing of it is, the old sow drives like a dream; just doesn't turn short enough. :>(
Thanks for your help,
Allan
third party image
the tractor vet
12-29-2005 18:38:46
Looks like yours was a tri. and someone went bone yard hoppen and got one off a 60-56 seires as that's not the one for it if that is and 66-86 seires.
Allan in NE
12-29-2005 18:25:39
And another thing,
Now, I really, really, REALLY suspect this is a "throw together" tractor from a salvage yard.
Further, I suspect it came from the same darned place that tried to sell me the 806 3-point hitch too. 'Cause, to quote them, "They are all the same". Betcha I got the 806 front end too. :>(
Signed,
Dummy
john d
12-29-2005 18:31:38
 Re: Wide Front End Headaches (Long) in reply to Allan in NE, 12-29-2005 18:25:39
Hang in there, Allan....as long as you aren't finding green paint, there's hope!
Allan in NE
12-29-2005 18:55:07
 Re: Wide Front End Headaches (Long) in reply to john d, 12-29-2005 18:31:38
Oh Heck Yeah,
I'll get the old beast straightened out.
But, I'm sittin' here running all this thru my mind and it is all coming together as a "picture" the longer I think about it. :>(
The 3-point hitch out of the salvage yard was part of a "trade deal" with the guy I bought the tractor from, The loader was welded on the tractor, there isn't a matchin' tire on the the old joker, it has a replacement engine, and now this front end gizmo. Me thinks me gots a heinz 57 here.
Ignorance is bliss and I gotta tell ya, I sure felt better before I talked to you boys tonight. :>)
Allan
Allan in NE
12-29-2005 18:54:39
Oh Heck Yeah,
Allan
wolfman
12-29-2005 17:51:32
Allan, I have a 656 & an 826 wide fronts. Your pic looks more like the 826's. Both turn quite short. Wolfy in PA.
Allan in NE
12-29-2005 18:08:53
 Re: Wide Front End Headaches (Long) in reply to wolfman, 12-29-2005 17:51:32
The more we visit about this, the more I think that it has a large chassis front end on this small chassis tractor.
The front bolts on that back ball bolster come up right at the motor/side rail mounting. I really don't wanna show you how the prior owner and his welder cobbled that mess up! :>(
Allan
ejr-IA.
12-29-2005 17:47:37
What I can remeber is they changed when they went from the 56 to the 66 series like in 73 maybe!
Steven@ND
12-29-2005 17:46:46
Same front end that is on our 1256, doesn't turn all that sharp.
Robhkent
12-29-2005 17:35:40
Allan:
That looks just like the one under my 856. I can't make it turn sharp enough for me either. when you get it figured out let me know!! :-)
Rob
Allan in NE
12-29-2005 17:40:29
 Re: Wide Front End Headaches (Long) in reply to Robhkent, 12-29-2005 17:35:40
Thanks Rob,
I've never had a tractor act like this. That old 656 I had would spin around on a dime and hand ya some change.
It just irritates me. :>(
Allan
TN 806
12-29-2005 17:33:37
I have a 73 and 76 model 666. They have cast front.
Allan in NE
12-29-2005 17:37:01
 Re: Wide Front End Headaches (Long) in reply to TN 806, 12-29-2005 17:33:37
Thanks,
Does this thing look like a front end off of an old 400 or 560? It just does not look right to me, that's fer sure.
Allan
TN 806
12-29-2005 17:42:02
 Re: Wide Front End Headaches (Long) in reply to Allan in NE, 12-29-2005 17:37:01
Looks like 706 or 806.
Allan in NE
12-29-2005 17:46:06
 Re: Wide Front End Headaches (Long) in reply to TN 806, 12-29-2005 17:42:02
Well,
That would sure explain it then 'cause they are both large frame tractors with a bigger turning radius.
Thanks for your help, I appreciate it.
Allan
