42' M cylinder head crack
bitbythebug
01-05-2006 21:33:07
I was just cleaning up the gasket surfaces on my M head when I spotted a crack. It is off of the oval shaped coolant port and goes for about an inch up in between the third and fourth combustion chamber on the head gasket surface of the head. Any input on this would be great. Is it something that needs to be repaired or replaced? Also kinda looks like one starting off of the front oval between one and two. Or should I throw a gasket in and see what happens? The reason I removed head was for a stuck valve, as I bought the tractor not running, and had been sitting for several years. Thanx.
Dan
Steven D. Esser
01-08-2006 12:43:03
 Re: 42' M cylinder head crack in reply to bitbythebug, 01-05-2006 21:33:07
I replaced the headgasket on my 400 because I was finding coolant in the oil. That did not fix it though. I put Stop Leak in it and it fixed it. I got lucky. It looked like the no.4 cylinder liner may have been installed in a rough and tough manner.
Michael Soldan
01-06-2006 06:41:10
I'm with Cowman. I did a Jeep for my son and when I took the head in for work they told me it had a tiny crack..machinist asked what I was doing with the head..if it was for a customer replace it as you didn't want problems down the road..if it was for me..it would likely be alright....that was 6 years ago and we still have the Jeep.."Larry" (Laredo)..... .....Mike in Exeter Ontario
Nebraska Cowman
01-06-2006 04:02:38
I guess it wouldn't hurt to try it.
hassan fortney
01-05-2006 22:14:13
is the crack going from the coolant passage to the combustion chamber? if so yeah probly should be delt with.
hassan fortney
01-06-2006 14:21:06
 Re: 42' M cylinder head crack in reply to hassan fortney, 01-05-2006 22:14:13
between the 3rd and 4th cylinder okay have a machie shop check it they will either magna flux it or dye it.
they can detrmine if its a problem.
remember that may be 1 thousanth now when she heat up and is torqed down that will change.
bitbythebug
01-05-2006 22:34:11
actually, it goes right down the center where the gasket would seal between the third and forth cumbustion chamber.
