Decals
Andrew D
01-12-2006 15:58:54
I have recently bought a Decal kit for my Farmall Super A. I would like to know where to put the cresent shaped ones that have the letters O D B and L H D B . Also the two Caution stickers that warn to keep hands and clothing away from fan and belts. Could anyone help me ?
Andrew D
01-13-2006 05:20:04
 Re: Decals in reply to Andrew D, 01-12-2006 15:58:54
thanks for the info. :)
gene bender
01-13-2006 01:39:14
For your SA you need the ODB placed on the left side of the lite sw in vert position. May have to move the pointer on the knob to line up with the decal just remove the screw and replace so the pointer lines up. The other decal was not original and could be placed anywhere you like.
Georgia Boy
01-12-2006 18:12:45
The ODB and LHDB are for the light switch on the instrument panel. I'm not sure about the caution stickers.
IaGary
01-12-2006 18:00:54
The lettered ones mark the position of the lite switch. You only use one of the two depending on which switch you have. O=off D=dim B=bright or and back, L=low charge H= high charge d=dim B=bright. And I'm not sure the exact spot for the caution sticker. Hope this helps.
