fuel filter
Bill Finn
01-12-2006 16:04:35
Have a 1963 IH 444 that runs at idle but when given gas breaks up. The fuel filter spurts but never obtains a level equal to the dischage side.
Shouldn't the filter fill up?
Bill Finn
01-13-2006 14:26:43
 Re: fuel filter in reply to Bill Finn, 01-12-2006 16:04:35
Mike thanks for your response.
Its a gasser and runs rough when cold but starts rather well however when it warms it begins to miss badly. I noticed that the fuel filter which is clear only gets about 1/8 inch of fuel in it and the barrel is 1 3/4 inches high. Fuel barely reaches the outlet side of the fuel filter.
This is a friends unit and tomorrow we are going to blow the fuel line back to the tank.
It just seems strange that so low a level of fuel is in the filter element.
Any suggestions you may have will be appreciated.
Thanks again,
Bill
Michael Soldan
01-12-2006 19:35:56
Hi Bill, can you give us more information. When you say the tractor breaks up do you meam sputters and stalls? Is it a gasoline model? I'm not sure what you mean by the fuel filter spurts. If it is a diesel I would say that the filter or filters if two in a series should fill up with fuel. There could be a line blockage. I have had one of my diesels die on me and couldn't get a good flow of fuel out of the filter at the bottom so I had to go back from the filter to find the problem..it was in the bottom of the tank. Some filters have a pet cock on the bottom to let off any water in the fuel and there should be a good flow when they are open, but if a diesel definitely they should fill up and run full...Mike in Exeter Ontario
