whats the cheapest piston and sleeve kit? napa?
booe
01-15-2006 12:01:41
i am in need of a sleeve and ring kit for my 45 farmall m. i was wondering what the cheapest kit would be? i have found some kits but i cant get them without pistons and my pistons are in great shape just had one freeze up on me and the sleeve pulled out with it and busted so i was going to go ahead and re sleeve it and put all new rings in but i didnt know if the parts from napa were the cheapest or any good quality. thanks alot!
Jimmy King
01-15-2006 18:51:53
 Re: whats the cheapest piston and sleeve kit? napa in reply to booe, 01-15-2006 12:01:41
My Dad and I over hauled a 460D with the cheepest set we could find one time, A few years later it cost me another over haul plus added cost for the damage it did to the block. So beware.
Georgia Boy
01-15-2006 17:48:45
When I was looking for a kit for my A, I found this site to have the best price. The kit was made by Tisco. Look on the sidebar to the left and click on Engine Kits.
Ben Rauls
01-15-2006 17:05:41
Try batecorp.com i think you can buy single sleeves and pistons.
justin w
01-15-2006 13:54:01
how about a NOS IH 3 7/8" piston & sleeve kit for $275?? I have them available..
booe
01-15-2006 14:43:35
 Re: whats the cheapest piston and sleeve kit? napa in reply to justin w, 01-15-2006 13:54:01
justin w, is that for one cylinder or for the entire engine. and what all does it come with? thanks
justin w
01-15-2006 16:42:19
 Re: whats the cheapest piston and sleeve kit? napa in reply to booe, 01-15-2006 14:43:35
the set includes pistons, sleeves, rings, wrist pins, and wrist pin retainers for all 4 cylinders.
Booe
01-15-2006 17:00:40
 Re: whats the cheapest piston and sleeve kit? napa in reply to justin w, 01-15-2006 16:42:19
hey justin w, you should have an e-mail!
justin w
01-15-2006 17:20:57
 Re: whats the cheapest piston and sleeve kit? napa in reply to Booe, 01-15-2006 17:00:40
it should be working now..
Booe
01-16-2006 17:06:24
 Re: whats the cheapest piston and sleeve kit? napa in reply to justin w, 01-15-2006 17:20:57
well i dont need a throw out bearing or gasket set anymore. but i do want the piston and sleeve kit so just let me know how much i owe and how you want paid. thanks!
Booe
01-16-2006 04:17:39
and if your kit is complete with pistons, rings, retainers, and sleeves and is nos ih quality, then consider it sold! do you accept paypal? or let me know where to send a check! thanks
Booe
01-16-2006 04:15:14
im not sure if you got the e-mail i sent but by any chance do you have a gasket set and or bearings for the bottum end? thanks soo much!
El Toro
01-15-2006 15:15:12
I would say that's for four cylinders. Hal
PS: 4 sleeves, pistons & a set of rings
El Toro
01-15-2006 12:54:25
Buy a Clevite sleeve and piston kit and do it right. In the long run you will be glad you did.
Hal
BobOHIO
01-15-2006 12:39:34
I bought a cheap kit for a ford 8N and was disappointed. All poor quality and nothing was made in USA. Had to have the new valves ground by a machine shop to seat properly. Also had new rings ground by shop for proper end gap. This all cost me extra cash. I didn't save anything in the long run. Spend the extra money and be sure it is a quality kit made in the USA before ordering it.
RustyFarmall
01-15-2006 12:18:21
I understand the need to keep the cost down, but you also need to understand that there are some very low priced engine kits on the market today, and some of these kits have so many defects and other quality problems that they are not even worth what you pay for them, in other words, they are nothing more than junk, and cannot even be used. I have no experience with kits available from this site, so I will not comment on those. NAPA has always had a reputation of being high quality. Only you can make the final decision.
Andrew Z
01-15-2006 12:07:38
The sleeve kits on this site are pretty well priced. I think you can order a bare min. package for like $370 to to bad. Andrew
Brad in WI
01-15-2006 12:06:48
I did that to a Farmall H once. It never ran right after that and it only had 70 PSI of compression with new rings and a complete head job. If it was me doing the work on my OWN tractor I would go ahead and do all four sleeves, pistons, rings. If it is for somebody else just replace the one and ship it out. Not really sure about the price or quality, but look around don't buy the first "kit" that you find. Sometimes IH dealers can offer complete rebuild kits for less than Napa/CarQuest. Just my .02 cents worth.
Brad
MagMan
01-15-2006 16:12:07
 Re: whats the cheapest piston and sleeve kit? napa in reply to Brad in WI, 01-15-2006 12:06:48
I have bought 2 different kits one for an M and one for an H both cheap aftermarket. From two different companys,They both exceded my exspectations. The last one was for my H I had the machine shop clean up the top of the pistons a little for me becuase of the casting slag but even the machine shop said the looked like good pistons plus the came with a very good manufacture ring set.I can get sleeves seperate and rings seperate but for the price I would do the sleve kit with pistons rings and sleeves or the in frame kit it will save money buy buying the kit over piece by piece. If you want a price email me. JON
