Farmall 140 hydraulics
bubbanm
01-20-2006 05:58:11
I have a Farmall 140 and I need to check the fluid in the lift. Do you check it with the lift up or down? Also what do you put in it?
Thanks in advance for any help.
Haas
01-20-2006 07:10:04
 Re: Farmall 140 hydraulics in reply to bubbanm, 01-20-2006 05:58:11
You check the level with the rockshaft arms in the rear position. Level should be to the bottom of the fill hole. Use HyTran or a similar good quality tractor fluid in the Touch Control unit.
