504 ring gear repair
blairds
01-23-2006 19:08:50
do you have to remove frame rails and front end and then pull the engine? or is there an easy way
Yellott Canby
01-23-2006 19:18:34
 Re: 504 ring gear repair in reply to blairds, 01-23-2006 19:08:50
I think you can split the tractor without taking the frame rails off though I will have to look.I have a 656 which is similar.
I have to do the exact same thing to mine. Was trying to locate an American made ring gear but so far all the ones I have found have been imports from Turkey.Anyone had any experience with these? YC
gene bender
01-24-2006 02:45:25
 Re: 504 ring gear repair in reply to Yellott Canby, 01-23-2006 19:18:34
You can just remove it reverse it and put back on if this hasnt already been done. The other side of the teeth havent been used so just turn it around. A torch is needed to heat the ring so it will slip off. Clean the flywheel good and then heat it and it will slide rite back.
