Order Farmall Cub Parts Online
Farmall Cub parts
blue sky
01-27-2006 18:59:44
burning oil, power loss(don't know if ever had) and looking to rebuild. any suggestions on parts and if I'm looking at new rings or what?????
blue sky
01-28-2006 20:06:19
 Re: Farmall Cub parts in reply to blue sky, 01-27-2006 18:59:44
Great advice one and all..... ..... .especially yours "OLD". Like you ,I probably could have lifted it myself....at one time! I'll let you know how it turns out.
steveb05
01-28-2006 13:34:35
Blue sky check out the Farmall cub web site ther are some very Knowledgeable people that can point you in the right direction. Steve
gene (missouri)
01-28-2006 08:19:16
At a minimum you are looking at rings, valve work, gasket set, rod and main inserts. Just don't expect the minimum - it never is.
Depending on you mechanical ability. You can save some money by doing the disassembly and assembly work yourself.
Gene
old
01-27-2006 20:25:02
Cae/Ih is always the first place to look for parts, then this site and or value-----bilt. Best thing to do it open the engine up and have a good machine shop do the block and crank and head work and then good from there.
blue sky
01-28-2006 09:55:35
 Re: Farmall Cub parts in reply to old, 01-27-2006 20:25:02
I"ve pulled heads before but never whole block. I"m going to put compression gauge on it before I start,but i think that will only tell condition of ea cylinder,not if it"s valves or rings..... .right?
old
01-28-2006 10:26:52
 Re: Farmall Cub parts in reply to blue sky, 01-28-2006 09:55:35
It helps you figure out what it might be but compression only tell part of the story. Also if its rings and you don't do any thing to the valves they will go bad faster. And if its valves and you fix them but not the rings then the rings will drop out on you soon after doing the valves. Your lucky your working on a cub and a strong man can almost pull the engine on one with out an engine hoist etc. In my day I could do so but thats was years ago and well you know what I'm saying
blue sky
01-28-2006 07:34:55
Thanks..... ..... .sounds like finding a good shop is the first step. Any suggestions out there for N.Texas,North of Dallas-Ft Worth.Debating where I should order parts or have shop get.
old
01-28-2006 08:14:35
 Re: Farmall Cub parts in reply to blue sky, 01-28-2006 07:34:55
Well since I'm in Missouri I have no idea of what you have down that way. Up here I use O'reilly's and or Napa. Either place should have/know of a good machine shop. I also know O'reillys can and does have a lot of tractor parts
gene (missouri)
01-28-2006 08:24:26
 Re: Farmall Cub parts in reply to old, 01-28-2006 08:14:35
Have the machine shop obtain the parts. The engine has to be disassembled, cleaned, measured and perhaps machined before parts are ordered.
Where to find a machine shop? Ask for recommendations at several local autoparts stores. They will know best machine shop in your area.
Gene
old
01-28-2006 08:42:44
 Re: Farmall Cub parts in reply to gene (missouri), 01-28-2006 08:24:26
Gene you should post that to him not me that way he get an e-mail notification sending it to me he doesn't. LOL
