can someone tell me the year of this m?
Booe
01-29-2006 09:02:39
i am trying to figure out what year this m is but im not having any luck! the id plate is pretty beat up but i found that the serial number on the tractor is 7702. and the number on the block is 6722-DH. so would that make the tractor a 40 and the block a 45? im ordering a set of bearings from this site and im having a heck of a time figuring out what ones to get. i dotn want to spend 150$ bucks on the wrong parts! thanks alot!
old
01-29-2006 09:06:12
 Re: can someone tell me the year of this m? in reply to Booe, 01-29-2006 09:02:39
Well if your talking about rod and main bearings you need to open up the engine and have the crank checked before you order bearing. You my need to have the crank turned and if you do then you will not know what you need til that has been done. Also the machine shop should be able to get the bearings for you
