300u
az tony
02-03-2006 06:02:05
I have a international harvester 300 utility tractor. I need to tow it how big of a trailer do i need? will a car hauler work or do i need something bigger? Does anyone know how much this tractor weights? it has a frontend loader and rear blade but can be removed if need be thanks tony.
PAULIH300
02-03-2006 10:54:59
 Re: 300u in reply to az tony, 02-03-2006 06:02:05
Well,there is always the option of driving it(the Ute) home.....that is as long as the tires are good,it runs dependably,and the steering doesnt have a ton of free play.....and you arent in a hurry getting there...
CNKS
02-03-2006 09:27:24
Keep in mind that the GVW of most "standard" car trailers is 7000 lbs or less including the trailer. Higher GVW ones are available. With 7000 lbs GVW you are maxed out with a 5000 lb tractor.
CNKS
02-03-2006 09:29:18
 Re: 300u in reply to CNKS, 02-03-2006 09:27:24
That assumes that the trailer weighs 2000 lbs, mine weighs about 2100 but has a steel deck.
TDK
02-03-2006 09:14:45
We weighted one a while back & it was 4300 lbs. No fluid or wheel weights. With a heavy loader & blade, weights & fluid it probably would't go over 6000 lbs.
Dellbertt
02-03-2006 07:27:49
I brought home one of my 300U with a mounted forklift attached on a 16ft tandem wheel trailer. About 450 miles. Nothing special. I assume you are not talking about using a wheel dolly.
Just make sure all tires are up and in good shape.
