Farmall H water pump
Bill in TN
02-13-2006 19:50:42
I am about to replace the packing, bearings and seals in the water pump. The service manual says to install the seals with the lips toward the fan. It seems to me that the front seal lip should face the bearing to keep the grease from coming out the front. Anyone know the reasoning for that. Also, is there a trick to get the old packing out.
Thanks, Bill in TN
kfox
02-14-2006 15:13:18
 Re: Farmall H water pump in reply to Bill in TN, 02-13-2006 19:50:42
Bill, I think the seal is installed that way so the grease can come out instead of forcing it back into the water. You can make a packing puller out of a spring (small, like a auto throttle spring) just straighten out a couple of inches and bend a short right angle on the end.Use a screwdriver to push the hook into the packing at a angle then straighten the wire up and pull. Kinda fishhook like. Sometimes old packing can be a bear to get out.
