wisconsin from wisconsin
all for school
02-13-2006 19:52:44
hello i was wondering if i could get some parts without paying to much. the parts i need from is a VF4 wisconsin, i need a distributor and a fuel pump. if any one could help thanks brandon
JT
02-14-2006 13:54:46
 Re: wisconsin from wisconsin in reply to all for school, 02-13-2006 19:52:44
If you can get the distributor number, might possibly be able to get what you need. If you want, email me the numbers and I will get you prices and part numbers
Jim
Janicholson
02-14-2006 06:02:29
Almost all V4s had magneto Ign.
Be sure of what you are asking for. El Toro is on track with a source.
JimN
El Toro
02-14-2006 09:24:46
 Re: wisconsin from wisconsin in reply to Janicholson, 02-14-2006 06:02:29
My book shows the VF4 using a distributor from 1950 thru 1974 using distr. # IGW-4159A and from 1951 thru 1980 using distr # IAD-4036A. Hal
captaink
02-14-2006 07:01:40
You are right that the VE4 & VF4 had magnetos and this is probably what he needs and he does need to be sure. If it is a magneto I would suggest a WICO if he can get one, they seemed to start a bit better than a Fairbanks Morse (at least for us).
However, later Wisconsin engines like the VG4 & VH4 (which is a close cousin to the VF4) had distributors on them. I had one of each that had distributors and I think they were made by Autolite. The distributor was driven off the back side of the generator if I remember correctly, and the generator was driven the same place as the magneto on the old VE4 & VF4.
El Toro
02-14-2006 05:49:24
Jump over to page #5 on this forum and look for Colorado Curt's reply to your posting several days ago. He has a seized VF4 engine. Send him an email to see if your parts needed are on his engine. Hal
