M Seat Support
Bud W
02-18-2006 17:18:22
What year M's used the curved post style seat support. I have a 48 MV with this support. Will the later model supports with spring and shock absorber bolt directly to the earlier model attachment points? Thanks
john *.?-!.* cub owner
02-18-2006 19:51:52
 Re: M Seat Support in reply to Bud W, 02-18-2006 17:18:22
If you want a real thrill, see what happens if the bolt through the center of the spring breaks. Happened to Dad once. You drop aobut 6 inches as the end of the bolt goes up past your nose. LOL
NDS
02-18-2006 18:13:35
The shock type seats were optional on Ms do not know when they were first available. Parts book shows`pipe type seat for FBK 9287 and up and shock type seats as (special). The mounting holes on deck are the same from FBK 9287 up.
CNKS
02-18-2006 18:10:39
Except for the 39-40? slot tops, the seats are interchangeable. Some 48's were equipped with the aftermarket Monroe seat with the large shock behind the spring. I have a 47 M that I replaced the old curved style seat for the newer style with the small shock -- direct bolt on.
Randy-IA
02-18-2006 20:10:30
 Re: M Seat Support in reply to CNKS, 02-18-2006 18:10:39
CNKS , I have one of those monroe seats on my 47 M . Do you know if parts are available to fix the pivot points and is the spring interchangable with the other coil spring seats ? I weigh 265 and the spring I have just don't cut it ! Thanks for letting me interupt ...Randy
CNKS
02-19-2006 14:18:44
 Re: M Seat Support in reply to Randy-IA, 02-18-2006 20:10:30
You or someone else asked about the spring a while back. I think all the new springs are the heavy duty type. I have the opposite problem, I weigh 100 pounds less than you and would rather have a lighter one, as the seat does not depress enough. I believe all the other parts except the shock are interchangeable on both, but I have not compared them.
RustyFarmall
02-19-2006 07:02:01
Randy, new pivot pins are available. A heavy duty seat spring used to be available, don"t know if it still is or not. I have seen several heavier guys equip the seats with dual springs, one inside of the other.
