wisconsin wiring
all for school
02-21-2006 20:47:16
hello i have a wisconsin vf4 and i need some help on the wiring system. what i really need is how the wires connect from the genarater to the distributor. and others, but those are the main ones.. if someone could help thanks brandon
El Toro
02-23-2006 06:19:43
 Re: wisconsin wiring in reply to all for school, 02-21-2006 20:47:16
Send an email to jbuzzetta@ckpower.com to see if they have a wiring diagram. Hal
MACE
02-22-2006 18:47:25
Go to wisconsins web site and download all the info you need from there.
MACE
mark k
02-22-2006 05:09:22
I have sent you an e-mail and will fax you a diagram. Mark
El Toro
02-22-2006 04:33:39
If this engine has battery ignition with electric start your ignition switch should feed voltage to the coil and distributor. The switch is either fed voltage from the starter solenoid or from the battery. Your generator should be wired to a
regulator to control the charging rate. All the generator and regulator does is keep the battery charged.
If this engine has a magneto it doesn't need any voltage because they create their own voltage with the magnets passing past the coil. I would check with Binder Books for a manual that covers the wiring for the VF4. Call 1-800-922-5632 to see if they have a wiring diagram and will fax you a copy or mail it. Hal
FatRedneck
02-22-2006 04:16:13
I'm not familiar with the wisconsin, but i'm sure you can get a shop manual for it.
