International 300 Utility
BillyBob from K
02-27-2006 15:17:21
I have an International Harvester 300 Utility with Torque Amplifier. I would like to know what model year it is and any other info on it. The numbers on the engine are C169 & 16B. On the transmission is 360486-R3. And on the rear section by the seat is 360558 R3. Please help me get to know my tractor.
RICK/OASIS IDAHO
02-28-2006 14:00:47
 Re: International 300 Utility in reply to BillyBob from Kossuth, 02-27-2006 15:17:21
Nathan is correct it is a 1956. the C169 is the engine type/ size. I bought a Farmall 300 last summer and have spent a lot of time getting to know it as you are doing now. My book says it is a 37 hp although when buying my engine kit i ran across something that indicated it is a 39 1/2 hp so i'm not sure which it is.
02-28-2006 10:23:54
Yes...there is a plate near the gas sediment bowl. The numbers on it are 22916 SJ. Does that tell me something about what model year it is? Paul says it can only be a "55 or "56. Does this narrow it down to a particular year? What is the HP rating on this model?
PAULIH300
02-27-2006 16:33:49
As its a 300U it can only be a 1955 or 1956.There is supposed to be a data plate on the right hand side between the dash and distributor.
JLE
02-28-2006 03:59:39
 Re: International 300 Utility in reply to PAULIH300, 02-27-2006 16:33:49
Ser. tag is near the gas sediment bowl, mounted to the clutch housing.
