Order Farmall Cub Parts Online
WIDTH OF A CUB
BART
01-10-2000 06:54:49
CAN ANYBODY TELL WHAT THE OVERALL WIDTH OF A CUB IS. FROM OUTSIDE TO OUTSIDE OF THE BACK TIRES. THANKS.
Jim Becker
01-10-2000 20:47:02
 Re: WIDTH OF A CUB in reply to BART, 01-10-2000 06:54:49
Rear tread width of a Cub can be set from 40 to 56 inches. That measurement is to the center of the tires, so you would add the width of 1 tire to get the over-all. Tires widths vary, but about 9.5 inches is common.
Bill {Antique Acres}
01-10-2000 07:48:03
I have a 4X8 trailer that I sometimes put my Cub on. You have to be straight, but it fits right on. I use this when going short distances and don't want to hook up the 22ft. trailer. As said above though it depends on how the wheels are. But you can make it fit on a trailer as narrow as 4' or 48" which ever you please. Bill {Antique Acres}
Phil Auten
01-10-2000 07:17:46
Bart,
I don't know the exact width, but it'll fit on a 6' wide trailer. Of course, the width will be dependent on how the rear hubs are mounted, dish out or dish in and which way the rims are turned. If it's set to it's widest you might need a trailer nearly 8' wide if you don't want to unbolt wheels and turn them around.
Phil
