W6 radiator
Andrew Bale
03-02-2006 17:38:20
Does any one know if a M radiator is interchangeable to my W6, if not does anyone have the OEM part number. This is the last piece to my puzzle and I need a radiator. Please email me abale@rochester.rr.com Thank you very much Andy
BIG JOHN
03-02-2006 18:18:59
 Re: W6 radiator in reply to Andrew Bale, 03-02-2006 17:38:20
Yes you can put an M radiator in a W6 but you can NOT put a W6 radiator in an M. The only difference is the hole in the top tank for the M steering shaft on the M radiators which is not present in the W6 radiators.
GOOD LUCK
John M
03-03-2006 03:19:48
 Re: W6 radiator in reply to BIG JOHN, 03-02-2006 18:18:59
Mine has the hole.Every 4 and 6 series Ive seen have the hole.Not saying every one Ive seen hasnt been changed,but they have had the hole.
RustyFarmall
03-03-2006 05:28:51
 Re: W6 radiator in reply to John M, 03-03-2006 03:19:48
John, I have a 1941 I-4 that does not have the hole for the steering shaft. Or, I should say the original radiator does not have the hole. When this tractor gets put back together it will have an H radiator in it.
John M
03-03-2006 14:31:15
 Re: W6 radiator in reply to RustyFarmall, 03-03-2006 05:28:51
Interesting! My 45 I-4 has the hole,and the I-6 im slowly taking apart has the hole.Maybe that explains why I have some work to do on the grills on both.but,I really have never seen one on a -4, or -6 that didnt have a hole like the Hs and Ms,so I just assumed all of them were like that.
Bencie
03-03-2006 16:21:12
 Re: W6 radiator in reply to John M, 03-03-2006 14:31:15
Hmm...seems to me IH might have messed up, could have saved some money on tooling and put holes in all of them if they interchange.
John M
03-04-2006 06:41:47
 Re: W6 radiator in reply to Bencie, 03-03-2006 16:21:12
That was my thinking as well.
