Strange Model A
Brig Landmeier
03-03-2006 15:03:22
I recently purchased a Farmall A with a s/n FAA 345189 which would elude to it being a 1953 Farmall A. However my tractor has a wide rear axle and a wide front end! Unlike any other model A I have seen, the engine is mounted exactly in the center much like a B model. If anyone happens to know what I might have on my hands please help me out, I'm getting the fever. Thanks!
Charles McNelly III
03-04-2006 11:11:10
 Re: Strange Model A in reply to Brig Landmeier, 03-03-2006 15:03:22
Hi Brig, It sounds like someone just added the axle off of a B. I"m building a wide frontend for my B. I"m using a steering box off of a A and then I replaced the axle with a wider one. Looks factory. Good way to add front weight without hanging a bunch of weight to the front. Good Luck.
Charles
gene bender
03-04-2006 03:48:02
The A or B or BN differental housing can be bolted to the left side and then use the differental shaft to go with the housing. Super C stuff will not go on the rear. Are you sure that the left tire isnt just moved out to the wide position. I s the fender mounted to the transmision. If not the space from the tranny to the fender will be either 18in or 22. let us know what you find.
RN
03-03-2006 16:15:19
Posting last summer out of Michigan area(?) about a wide front B/A combination that had been used for special veggy crop work- apparently axles from B could be connected to A transmission and a C type adjustable wide front mounted offset one side. A,B,Cs shared lot of parts, interchange possible. After 50 years many things could have been modified. Could be a B base with wide front? check back if you figure it out. RN
Bencie
03-03-2006 15:54:44
Might be something someone put together, half A, and half B?
Dave_Id
03-03-2006 15:15:02
I don't exactly know what you mean, but your Super A has an adjustable wfe, and the rear wheels can be switched around, to make at least 8 different widths,. Is it set up for the wide width, and that is unfamiliar to you?
