Farmall Fenders
Broomstacker
03-06-2006 16:57:18
OK, I've seen fenders for sale for: 300,350, 400, 450; ...and I've seen fenders for sale for 544, 566, 606, 706, et al.
I never see fenders listed for 460 and/or 560. Were 460 rowcrop original fenders clam shell, or flat tops? Will the H. M, 300--450 clamshells work? Thanks and regards.
CNKS
03-06-2006 17:37:18
 Re: Farmall Fenders in reply to Broomstacker, 03-06-2006 16:57:18
The more tractors made the more fenders, also it is more likely that someone will make them. Don't know how that statement applies to a relatively low production 544, may be there are more in your area, or maybe that fender fits several models. 460/560 fenders were clamshell, the base of the H/M fenders will mount into the bolt holes on the axle housings, but on the 460/560 they will look a little weird because they are a smaller fender with a different shape. As of about a year ago there were no aftermarket ones for the 460/560, doubt if there are now -- Used ones are out there, you just have to look. I adapted early 706 fenders to my 460, the base is different, I think the fenders themselves are the same, if not they are close. I cut the clamps off of them and had a flat steel plate welded to the bottom. Original, no, but they work.
RustyFarmall
03-06-2006 18:21:14
 Re: Farmall Fenders in reply to CNKS, 03-06-2006 17:37:18
Just checked with the warehouse, no aftermarket fenders for the 460 or 560. They are available for the C through 450 though.
Broomstacker
03-06-2006 17:54:54
Super! That's about what I figured! Thanks, CNKS!
