another SA tranny ?
banjo
03-09-2006 11:49:37
was reading in shop manual about a rivet in the reverse gear. I see the hole but i guess mine is mia. Also what is the outer edge of the oil gear supposed to look like. Mine has flat surfaces. But there also looks like some teeth in areas.Short teeth. i hav'nt rotated it so i can get a good look at it.
Just hopeing i dont have to do a complete tear down.
banjo
03-09-2006 22:23:10
 Re: another SA tranny ? in reply to banjo, 03-09-2006 11:49:37
Why did i have a feeling someone would say that.
evidently it must of got out of time and the reverse gear teeth hammered them flat.as they look hammered flat not broken.
Are these oil slinger gears available? and where? i have no idea where a dealer is located in my area. southeast okla.
This looks like a nice project, final drive & differential housing,pto cover,main spline shaft.
I may not tackle it right off.After i get everything unhooked from the transmission how heavy is the transmission with the shafts and gears?
Jim Becker
03-09-2006 20:44:52
The oil slinger should have teeth all the way around it just like any other gear.
