Tractor Vet
Big Red M 46
03-12-2006 09:39:17
Okay, I pulled the tractor apart again today and measured the distance from the step to the face on the clutch and it is only 1.360 not the required 1.406. Before I had the flywheel turned all the adjustments were already maxed out. I think that I had better get a different flywheel. Thanks to all who have given me advice through all of this. I hope replacing the flywheel helps. I have posted on this topic twice before for those wondering what I am talking about.
the tractor vet
03-12-2006 10:04:15
 Re: Tractor Vet in reply to Big Red M 46, 03-12-2006 09:39:17
Well that tell me that they did not know what they were doing and so now you will have to try and find a good flywheel that has not been ground down to the max and when ya have it refaced use the massurements i gave ya . if they are ground down to much then the plate get to far away from the throw out bearing and ya run out of adjustment. and any ideas of adding lenght to the rod is not the answer as there is only somuch movment for the throwout bearing to move .
Big Red M 46
03-12-2006 15:13:32
 Re: Tractor Vet in reply to the tractor vet, 03-12-2006 10:04:15
Thanks for all the help, I am getting another flywheel tomorow at a local tractor donor yard. I hate to call them junk yards, alot of good still in them ol girls. Thanks again.
