To Wicksfield
Bob
03-21-2006 10:13:28
Since your alternator will excite at lower PRM's with power jumpered the the #1 "switched excite" terminal, you can run a wire from the #1 terminal to the ignition switch if it's distributor ignition.
Use a diode or an "idiot light" in the lead to the ignition switch to prevent current feedback, and engine "run-on" when the ignition is shut off. A 1N5008 diode works GREAT for this application. The cathode end (with a white band) goes toward the #1 terminal.
Third Party Image
With the simple wiring harness as shown, you would not even have needed a (silly) self-exciting alternator.
(The diode is shown uncovered for illustrative purposes, only. Before installation, I cover them with 2 layers of heat shrink tubing, to prevent the leads from flexing and breaking, due to vibration.)
Use a momentary "ON" pushbutton switch, or an oil pressure switch as in one of BobM's diagrams, if it has a magneto.
