m farmall
bm3501466
03-23-2006 13:05:21
I want to put a Chevy 350 CI engine in my M farmall. What all do I need to buy/custom make to get it to bolt right in?
RN
03-24-2006 02:58:29
 Re: m farmall in reply to bm3501466, 03-23-2006 13:05:21
Transmission adapter plate, motor mounts, governor unless you're just pulling/parade, maybe flywheel/clutch work, hoses, maybe side rails. Hood clearance on carb might be a problem. If you want a working tractor check puller forum for Chad S- maybe use a 560/460 engine or the combine equivalent instead. RN
FatRedneck
03-23-2006 16:17:54
nothin to say but what a waste of a good tractor!!!
Rrt
03-23-2006 19:04:53
 Re: m farmall in reply to FatRedneck, 03-23-2006 16:17:54
Boy FatRedNeck.....I'd say 7 out of the 10 times i see you post something it is usualy negative. My god CHILL OUT! You AREN"T GOD!
Mel in OR
03-23-2006 17:17:35
I agree.
