Metal hydraulic lines-Same on SC, SA and 140
BillWV
03-27-2006 12:47:18
YTers,
A friend is looking for parts for a 140. Are the hydraulic pump and metal lines to the touch control unit the same on Super C, Super A and 140?
Thanks,
Bill
Hugh MacKay
03-27-2006 18:28:49
 Re: Metal hydraulic lines-Same on SC, SA and 140 in reply to BillWV, 03-27-2006 12:47:18
Bill: Those hydraulic lines for C, SA, SC, 100, 200, 130 and 140 will all be the same with one exception. Any tractors with the IH factory remote valve as used on SC and 200 Fast Hitch. That same valve was used on all tractors if a customer wanted a remote valve from IH
El Toro
03-27-2006 14:45:33
Not sure about the pumps being the same, but I would think they would be. It would be easier to
use braided flex high pressure hose. They can be made for an exact fit and vibration won't affect them. Aeroquip, Alemite and Weatherhead sell the braided hose. They're easy to make up too. Hal
BillWV
03-27-2006 19:00:00
 Re: Metal hydraulic lines-Same on SC, SA and 140 in reply to El Toro, 03-27-2006 14:45:33
I"ve thought of the same thing for my SC, but wasn"t sure how to attach the hoses. Cut the metal lines off of the attachment blocks at the ends and weld/braze threaded fittings?
Thanks guys,
Bill
El Toro
03-28-2006 03:59:35
 Re: Metal hydraulic lines-Same on SC, SA and 140 in reply to BillWV, 03-27-2006 19:00:00
I would silver solder fittings on a short piece of the steel lines. If you take one of steel lines along to the store, they may have to correct hose ends. Could you email a closeup picture of the steel lines and of the pump if possible? Hal
Bompchomp@aol.com
BillWV
03-28-2006 04:28:54
 Re: Metal hydraulic lines-Same on SC, SA and 140 in reply to El Toro, 03-28-2006 03:59:35
Actually the parts he needs are missing. The tractor is an industrial 140 he bought at a state road sale; the pump and metal lines are gone and blocked off.
I think he will prefer the original metal lines to having custom lines made, but I'll mention it to him.
Thanks,
Bill
El Toro
03-28-2006 04:58:07
 Re: Metal hydraulic lines-Same on SC, SA and 140 in reply to BillWV, 03-28-2006 04:28:54
He may be able to get the pump and steel lines from a tractor salvage yard. Here's a web site for salvage yards. Some may be in your area. Hal
PS: I only see one in WV.
http://www.epartdirect.com/index.php?t=fc&s=s
