10-20 questions
Bill Geer
04-13-2006 22:12:14
Anybody care to anser some questions about a 10-20 mccormick?
1. Why is the clutch pedal on the right?
2.Does it have a hand or foot break? All I have is a drum on the left side of trans case.
3.why is it yellow? I was thiken gray or red.
4. What are the little things on the valve cover? two flip up and two turn to the side.
Thanks Bill
ihc49er
04-16-2006 16:28:04
 Re: 10-20 questions in reply to Bill Geer, 04-13-2006 22:12:14
Well now, your sittin on your old tractor plowing, Wheres the right fr.& rear wheel? pretty aukward to press the clutch on the left,when your sittin on the right.thats why a lot of times you only see the rear wheel extention on the left. And the HAND Brake is on the left also!
Nebraska Cowman
04-14-2006 04:08:42
1. Maybe the engineer was left-handed? Why did John Deere put the hand-clutch on the right?
2. The brake was operated by lever on the left side.
3. Maybe the owner had a bunch of yellow paint he wanted to use up?
4. The flip-up lids are for oiling the valve lifters once a day. The screw-out caps are primer cups for starting.
