Thermostat?
Andrew Betzner
04-18-2006 08:26:58
I have a 51 H and the housing where the thermostat is supposed to be has this wierd spring thing there unstead of a thermostat. Is the thermo supposed to go behind the spring thingy or is the spring thingy some kind of weird thermo?
Dumb Bob
04-18-2006 10:13:53
 Re: Thermostat? in reply to Andrew Betzner, 04-18-2006 08:26:58
Question for Bob M. Will that AutoZone #800-180 thermostat work in a model M as well?
Bob M
04-18-2006 17:46:15
 Re: Thermostat? in reply to Dumb Bob, 04-18-2006 10:13:53
Yes!!
Bob M
04-18-2006 09:19:10
Andrew - That "spring thing" is probably the remnants of the original thermostat. Unlike modern automotive t'stats the OEM unit is quite large and complex (and priced accordingly).
Best bet is to dig out that spring (and any other bits of the t'stat probably still stuck in the housing) and install a new t'stat.
Alternative to an OEM t'stat: The Autozone #800-180 thermostat. It looks different but it fits and works fine in an H. And under $5 it's considerably cheaper than the OEM style t'stat!
Yugrotcart
04-18-2006 18:01:47
 Re: Thermostat? in reply to Bob M, 04-18-2006 09:19:10
You don't happen to have a NAPA # for that as well, no Auto Zones in Canada..... ...
RustyFarmall
04-18-2006 08:50:22
Not real sure what you are describing but I do know that the original thermostat does not look anything like the thermostat in your car or truck, in fact, it does sort of resemble a spring or bellows.
