POWER STEERING
BOBM25
04-19-2006 09:04:22
Is it possible to use the factory live hydraulic pump on an SMDTA to run a Char-Lynn power steering motor. I've been told there is a small adaptor block that can be used to get lines to the motor. Thanks for any help in advance.
BOBM25
04-20-2006 08:50:29
 Re: POWER STEERING in reply to BOBM25, 04-19-2006 09:04:22
Thanks guys, I think I got something figured out now. Just need to get the parts!
BOBM25
04-19-2006 11:54:58
Can either of you guys send me a picture of your setup or let me know where you got the stuff you needed? Thanks
Bob M
04-19-2006 18:13:00
 Re: POWER STEERING in reply to BOBM25, 04-19-2006 11:54:58
Punch below! Image shows the priority valve included with the original Charlynn PS kit about 35 years ago.
However as 26Red suggests it's probably easiest to get a valve from your local hydraulic house.
26Red
04-19-2006 15:31:42
I bought mine at force america. I think it's called an adjustable priority valve.. You local hydraulic cylinder retailer should be able to get them.
Force america also sells the charlynn torque generator too.
Bob M
04-19-2006 11:31:48
My SM has a priority valve (flow divider) ahead of the christmas tree valve to supply the Charlynn PS unit from the live pump. It works great.
26Red
04-19-2006 10:23:32
You can get an adjustable flow control valve for about $80. This will maintain hydraulic fluid flow to the powersteering which needs about 3 gals/min to work well.
I have a similar system on my 300 and it works well.
