Noisy in Belt Pulley Housing
Bobby in SC
04-20-2006 18:45:06
I have a Farmall Super A, 1953. There is a grinding noise in the pulley housing. Sounds as if there is no fluid in housing. I took loose the inspection stud and it is full of oil and there seems to be very little play between gear teeth. To eliminate the outer bearing, I took it off and turned the shaft by hand and still get the same noise. I have also heard that the Super A's were naturally noisy. Any truth to this or am I in for a surprise? Never been into one, any help appreciated.
gene bender
04-21-2006 02:53:09
 Re: Noisy in Belt Pulley Housing in reply to Bobby in SC, 04-20-2006 18:45:06
There were shims to set back play on the gears that went between the trans housing and the belt pulley attachment and maybe someone took them out. If you dont use the pto dont worry about it.
