Injector removal suggestions
AGR538
04-21-2006 06:07:35
I need to pull out an injector on a Super MD. I have never done this before on an MD but with past experience on other diesel tractors I know it will not be easy. Does anyone have any suggestions or tricks that could make this a more pleasant experience? Are there things I should NOT do? Thanks
Andy Martin
04-21-2006 13:55:07
 Re: Injector removal suggestions in reply to AGR538, 04-21-2006 06:07:35
I just pulled the same injectors from a 450D. they all came out by hand except for one.
If thye don't come you can wedge under both sides but go easy so as to not break off the ears. A little tapping may rotate and help it get started. Penetrant sitting a few days on a tough one should help.
I had a real tough one on a TD-14 a few years back and gave up instead of breaking something so I was nervous about the 450D but it was not an issue.
