rear main oil seal leaking on MD
Brad in WI
04-23-2006 12:48:55
I have a leaking rear main oil seal on my MD. I am unsure if it is a one piece seal that I can put in without removing the crankshaft or do I have to remove the crank. Thanks for the help in advance.
Brad
CNKS
04-23-2006 14:44:37
 Re: rear main oil seal leaking on MD in reply to Brad in WI, 04-23-2006 12:48:55
You have to split the tractor.
Brad in WI
04-23-2006 16:58:35
 Re: rear main oil seal leaking on MD in reply to CNKS, 04-23-2006 14:44:37
I know that I have to split the tractor but I am wondering if I have to pull the crankshaft or not.
Brad
Dave Slater
04-23-2006 17:39:24
 Re: rear main oil seal leaking on MD in reply to Brad in WI, 04-23-2006 16:58:35
Don't have to remove crank,but I would check the main bearings because if to much clearance the seal will start leaking agian later. There was 2 type rear seal used,you will have rope type unless rear main seal update kit was installed sometime.It used neopreme seal.
Brad in WI
04-23-2006 18:12:14
 Re: rear main oil seal leaking on MD in reply to Dave Slater, 04-23-2006 17:39:24
the motor was completely overhauled 8 years ago with about 250-300 hours on it. The main bearings should not be wore out ( I think, I may be wrong) I am trying to avoid having to replace the bearings and possibly having to get the crankshaft ground again.
Brad
