Fast Hitch
BOBM25
05-11-2006 12:35:17
Isn't a fast hitch on a 300-560 supposed to have a swinging drawbar also? Or was it an option or something? If so where did they all go?
IH Forever
05-12-2006 12:59:00
 Re: Fast Hitch in reply to BOBM25, 05-11-2006 12:35:17
I think that they were an option. I have one on my Farmall 340. I actually have a couple for this tractor.
JMM
05-11-2006 18:22:56
I have a 300 and a 400 both with the swinging drawbar. It anchors with a pin to the front of the fast hitch yoke. It anchors to the slide in drawbar which supports the vertical load. They are heavy and a bit cumbersome to mount. They sure make you fell better when towing a heavy load. Puts the puling force up under the tractor. those are the only two ive seen
Dave Slater
05-11-2006 18:06:04
Yes they made them for those fast hitches. The swinging drawbar used on 300 ,400 that used two hydraulic cylinders on fast hitch was different than ones used on 350,450,560 fast hitch. Don't see them to often but theres some around.
CNKS
05-11-2006 17:13:13
DOn't think so as the main pull point on the fast hitch is the place where the swinging drawbar attaches to with no fast hitch. That was one of the problems, stress on the fast hitch bushings, etc when pulling trailing implements.
CNKS
05-11-2006 19:43:58
 Re: Fast Hitch in reply to CNKS, 05-11-2006 17:13:13
I retract the above statement. There is a place for a pin the front part of the yoke as Dave and JMM said above. In my parts book it does exclude the 460 Hi Utility I have. Apparantly the dimensions are different. There are also stabilizers that bolt to the fast hitch to minimize side sway when using the drawbar. Thus the wear I mentioned should be less if those are used.
Chris in Washington
05-11-2006 13:48:07
I can't speak for the 300-350 but the Super C with fast hitch had an optional swinging drawbar.
RayP(MI)
05-11-2006 18:45:13
 Re: Fast Hitch in reply to Chris in Washington, 05-11-2006 13:48:07
Think there is a swinging drawbar option for my 200... there is a place to attach on the front of the wisbone. Was probably optional, or lost on most tractors.
Allan In NE
05-11-2006 12:53:26
Might be mistaken, but I don't think they started the swinging drawbar option with the two point until the 656.
Allan
IaGary
05-12-2006 04:07:07
 Re: Fast Hitch in reply to Allan In NE, 05-11-2006 12:53:26
Allan my farmall 300 has the swinging drawbar that came new that way.
I bought the tractor from the guy that bought it new and thats the way he bought it.
Bout the only one I've seen tho.
Gary
