Shortening springs
BillWv
05-20-2006 19:25:50
YTers,
I need to make a couple of springs for my Super C brakes. I've had occasional success in the past by cutting the spring to the right length, heating and bending a new hook in the end. But more often, it breaks after a few uses. Any tips on tempering it so it won't break?
Can't find the right size locally, and would like to get it back together without waiting on parts.
Thanks,
Bill
Janicholson
05-21-2006 11:23:35
 Re: Shortening springs in reply to BillWv, 05-20-2006 19:25:50
After cutting to length take the cutoff piece and experiment with it. Bend some out as a loop and then quench it first in water, If it snaps, try cooling it slower in oil, Then if it snaps try air cooling, if still brittle try cooling it in ashes, last is to cool it in the air by removing heat gradually from the bend, then letting it cool. At some temper it will be tough, and not break, or be too flexible and stretch out.
Good luck, JimN
Hugh MacKay
05-21-2006 03:35:07
Bill: If you are talking about brake pedal retaining springs, I expect CaseIH will be your best source. I don't like their price, but they do work and they do last. I've tried numerous lower cost springs, and all turned out being more expensive, as they either broke or wouldn't hold the pedal back.
In 1992, I paid CaseIH over $25. each for those. It's now 14 years since I installed them, thus I can give a testimonial, they will last at least 35% as long as the originals. But then I do have some older originals still going.
In the long term, I find parts that CaseIH still supply are most economical for me. I rarely go elsewhere unless it's something they no longer supply.
