Pictures
Blue3992
05-22-2006 22:09:03
Here's the pictures, FYI, these were taken with the PTO guard off the tractor.
third party image
third party image
Nat 2
05-23-2006 04:54:17
 Re: Pictures in reply to Blue3992, 05-22-2006 22:09:03
Yep, back it up on to a steep hill so the tractor is facing downwards. All the oil will run to the front, and you can do whatever you want to the PTO unit.
I also agree that you should just get a complete unit. The entire unit must be removed and disassembled to replace that lever anyway. There's no way to do it from the outside.
Brad in WI
05-23-2006 01:53:39
If you don't want to drain out the oil, back onto a hill or trailer. Leaving the back of the tractor upwards, causing the oil to flow towards the front. Be sure to lock BOTH brakes, leave shifter in 1st gear or reverse and block BOTH back wheels to prevent the tractor from rolling away. Remember safety first.
Brad
arod
05-22-2006 22:28:13
well, I have replaced the pto dust seals off a farmall M before. No big deal. I know you don't want to, but drain the 13 gallons out. Remove the assembly, and tear that guy out, probably not that big a deal to remove. And heck, just install a new complete assembly, cause just purchasing that portion, some fella is going to have to tear it out, just like you need to. Probably no more than 20$ from a salvage yard.
