Farmall A
Barry Orbash
06-06-2006 06:23:18
I have a farmall A two weeks ago it was running fine now it takes a long time to start and when it does start it does not run smooth and will only run for a couple minutes. I replaced the points,condenser,spark plugs,plug wires,cleaned the carb and check the timing could the coil be bad? Thanks Barry
gene bender
06-07-2006 01:18:07
 Re: Farmall A in reply to Barry Orbash, 06-06-2006 06:23:18
With #1 spark plug out turn engine over and check when it is on T.D.C. that the rotor is lined up with the tower on the cap.
BillWV
06-06-2006 16:56:57
My first guesses would be an obstructed vent in the gas cap, or restricted fuel flow due to rust and junk in the gas tank.
Good luck,
Bill
old
06-06-2006 06:37:12
First off you should check the spark and see if its a nice blue spark or a weak yellow spark. Most of the time when a coil goes bad it is either bad or takes and hour or so to heat up and stop working. Or you could also have a gas flow problem, make sure you have a good steady flow of gas out of the carb drain plug. If you don't then check the fuel line/tank for problems
