Super H Carb
BigAl18
06-12-2006 18:29:09
I have a Super H that I just replaced in the float. The float was replaced by removing the bottom bowl, the entire carb was not taken off the tractor. The carb was adjusted and the tractor ran great. However, upon shut down, it begins to leak gas out of the choke. I thought the float became loose, but this is not the case. The tractor will start and run great, but upon shut down, it begins to leak gas, afer a few minutes. I am at a loss to the problem. I though I made all the proper adjustmenets, as the tractor starts and runs, but it looses gas once shut down. Any thoughts??
RustyFarmall
06-13-2006 04:27:08
 Re: Super H Carb in reply to BigAl18, 06-12-2006 18:29:09
Float adjustments are critical, both the height and the drop. It is nearly impossible to adjust the float with the carb on the tractor. A new float, right out of the box, is very seldom adjusted correctly.
farmhand
06-12-2006 18:46:00
Big al your float is set to high and not letting your needle shutoff in the seat or your needle and seat need to be replaced.
