BN wiring update
BobOHIO
06-18-2006 06:49:05
Worked on my BN charging problem. Cleaned grounds etc. Grounded the F terminal and nothing. Printed instructions John T posted that said to jump bat terminal on VR to A post of gen (I don't have the paper infront of me but I think that is what I did) and sure enough it charged great! I figure the VR is bad so took the top off and inside looked like brand new. Contacts are shiney and clean. Could it still be bad? Thanks
This is how I wired it:
1. Gen F to VR F
2. Gen A to VR gen terminal on bottom
3. VR bat to ammeter
4. Ammeter to battery/starter
5. VR L to lights (lights work good)
BobOHIO
06-18-2006 06:51:43
 Re: BN wiring update in reply to BobOHIO, 06-18-2006 06:49:05
Forgot to mention that when I did the test to jump the VR bat to A post of generator , the F post of generator was grounded at that time also. Thank you.
Janicholson
06-18-2006 10:28:18
 Re: BN wiring update in reply to BobOHIO, 06-18-2006 06:51:43
The regulator may need to be grounded the winding of the regulator that pulls in the cutout relay needs to go to ground to cause the connection to be made. Assure a good regulator ground. JimN
BobOHIO
06-18-2006 12:47:06
 Re: BN wiring update in reply to Janicholson, 06-18-2006 10:28:18
Thanks Jim. I cleaned up where the VR bolts to the genreator with some sandpaper. I'll try running a wire from it to ground and see what happens.
