IH 268 diesel starter grind
Bobby B
06-25-2006 10:29:45
I have a starer grind problem and have had the starter out about 10 times. I bought this unit back in March just finished engine rebuild things are fine but the starter. I know that the engine origanaly came with a bosch starter but was converted to a GM starter and the guy had holes machined for the GM starter. I have dressed out the flywheel a few times. Battery conections are clean and the batterys are good 1 is 800 and other is 500 amps. Any ideas ? thanks
Brownie 45
06-25-2006 17:08:37
 Re: IH 268 diesel starter grind in reply to Bobby B, 06-25-2006 10:29:45
Make certain that the starter drive gear is the proper one for your application. Sounds like the mesh of the drive gear & ring gear could be too tight. If the starter mounting bolt holes are a bit large, try adjusting the starter away from the ring gear as far as it will go. Of course, the flange which locates the starter in the bellhousing is going to determine if you will have any leeway. Worth a try.
