wd6 tractor
bob wing wang
06-26-2006 15:06:47
Hi on a wd6 tractor do you have to split it to work on the clutch and rear seal.
Yugrotcart
06-26-2006 17:42:47
 Re: wd6 tractor in reply to bob wing wang, 06-26-2006 15:06:47
Won't have to split it to get at the clutch. Just remove the "bell housing/ fuel tank support". You may able to remove the flywheel to get at the mainseal. Just did the rear main on my W6, service manual said it had to be split, I was able to do it without having to. Just make sure that you have 2 men and a boy around to lift out the flywheel, just a little heavy..... ...
Geoff NY
06-27-2006 13:00:54
 Re: wd6 tractor in reply to Yugrotcart, 06-26-2006 17:42:47
If you have found a way to remove the "bell housing fuel tank support" that doesn"t mean splitting the tractor, I would like to learn it.
