Camshaft lobe height on an H
Brad in WI
07-20-2006 10:07:35
Can someone tell me what the Low tolerence is on the lobe height on the camshaft for a 1941 Farmall H. I am rebuilding the motor to factory specs and want to make sure the cam is not worn out of tolerence. thanks Brad
riverbend
07-20-2006 20:03:24
 Re: Camshaft lobe height on an H in reply to Brad in WI, 07-20-2006 10:07:35
The lift on a standard H cam is 0.202". Super H had 0.240" After 65 years, how much is too much is up to you. Why not have it regound to stock or SH specs ? Be sure to have the lifters refaced at the same time. It may not matter much, but I would try to keep the lifters in order so they go back in the same hole after grinding.
Greg
Janicholson
07-20-2006 11:58:40
Cam regrind shops will know that spec easily, If it is better performance needed, use a 350 cam. (or specs) JimN
Magman
07-20-2006 11:42:08
I am not sure what the heith is without looking at the IT manual, But I think I may be wrong but I think they wear on the sides of the lobe more than the top and its real hard to mike them. JON
Brad in WI
07-20-2006 11:53:34
 Re: Camshaft lobe height on an H in reply to Magman, 07-20-2006 11:42:08
I work in a machine shop where I can set the cam up in a lathe and by using an indicator measure the height and sides of each lobe. I glanced through the I&T Manual and did not see the lobe height but did find the journal diameters.
brad
